Gas type 87 or 93
Old Apr 29, 2008 | 05:01 PM
slayerreigninblood's Avatar
Default Gas type 87 or 93
This is probably a no-brainer for you guys but...what type of gas do you recommend using for a 2008 sportsman 500 HO...and what is a ballpark estimate on miles you can go on a tank ...I realize riding conditions will impact the number but under normal trailriding conditions 50% hills/50% flat the rest at elevations between 1000-2000ft
Thanks
Old Apr 29, 2008 | 07:07 PM
sheepdogMSP8117's Avatar
87 octane, any higher than you need is just a waste of money. And you should be able to get 80 miles on a tank easily.
Old Apr 29, 2008 | 07:25 PM
Stay with the 87 octane. A lot of the 4 stroke engines don't need anything higher.
Old Apr 30, 2008 | 09:31 AM
05twin700's Avatar
the book for my 08 800 says 87 octane. so i would imagine the 500 would be the same. like everyone else said, anything higher than the required amount, is a waste of money.
Old Apr 30, 2008 | 03:32 PM
Jlutty444's Avatar
I'll chime in.
Yes on waste of money and..... There is a potential performance issue as the higher the octane, the slower the burn. I wonder if you would end up with an incomplete burn and pollute more? And without a complimentary advance in spark timing, it makes no difference in power.
Certainly a motor like this has less valve overlap and a higher resulting dynamic compression ratio, but the engineers who built it had a certain octane in mind.
I ran 92 in my XR650L (read: big ole four stroke) with alot of mods and it ran hotter without any noticeable gain in power. I wanted to keep temps down. I switched back.
Old Apr 30, 2008 | 06:28 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
higher octang is only good for higher compression engines which your is not so dont waste money on the already too damn high gas prices.
Old May 1, 2008 | 02:59 PM
jmkott's Avatar
For me in Minnesota, it's easy. By State law, only 91 octane is allowed to be sold without alcohol, so it's 91 for me.
The alcohol breaks down before I usually get through a full tank, especially when stored.
Old May 1, 2008 | 03:46 PM
Jlutty444's Avatar
If yours is a two- smoke like mine and your local gas has Alky in it, I would run Klotz Benol oil as it is supposed to suspend in alcohol as well.
Old May 1, 2008 | 08:24 PM
Thanks for the advice...I'm keeping it at 87
Old May 1, 2008 | 10:46 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
see as always i keep forgetting about the crap gas alot of staes have where we stil have decent gas up here so @ $3.63/ gallon for 87 ill stick w/ cheap lol.
