want start crank over fine
Old Apr 30, 2008 | 04:06 PM
john deere8640 's Avatar
Default want start crank over fine
[img]i/expressions/face-icon-small-sad.gif[/img]please help me and grandson get his 4 wheeler running asap ; it will not start we had carb. rebuilt and that hrlp gas problem but now we got weak fire replaced spark plug no help replaced ing. coil a little help . now we trying to find out how to get to exciter in fly wheel can any body help us with any of this mess please as i am disabled and cant afford a certfied mech . thanks frank reply asap to frankgiles47@yahoo.com also if you know where i might down load a sevice manual i would appricatethe battery is hot turning engine fine yes we tried pull start also,i would appricate help asap as he wants to ride this weekend
Old Apr 30, 2008 | 06:51 PM
tbsleeper's Avatar
kinda hard to understand what your saying. First i would make sure that your swithc on the handlebars is on. May be stupid but ive done this before and coudlnt figure out was wrong for about an hour. next i would make sure that you hooked the carb back up correctly.
Old Apr 30, 2008 | 06:52 PM
tbsleeper's Avatar
also make sure gas is on, it should be pointing straight down
Old May 1, 2008 | 12:15 AM
tbsleeper's Avatar
heres wat he said to me im gonna post it here incase anyone else has ideas.
i will try explain this problem better yes the switch on bar is on , i am get a weak spark thru srark plug or just thru srark plug lead , ok i got it to crank and run for about 3 min. then it quit i got fire weak fire i got gas . now on carb installition you got3 small ports the one on very bottom look like a oil line but iam postive it is right cause it to short to come out with carb. the others came out with carb. now iam not sure where they went.so far this is what i done replaced spark plug with new one replaced coil with a good used one .. and the carb. rebuild so what you suggest . contact me at frankgiles47@yahoo.com thanks frank
are you guys trying to pull start it or using hte electric starter? i would try both if your only using electric starter as it might not have enough power to turn the motor over or sometihng. try starting a full throttle also and check wires above oil tank to make sure non were nibbled on by mice.
Old May 1, 2008 | 05:41 PM
hey guys we have tried all the suggestions but still the same the only thing i made a eror on first page it is a polaris 2003 250 trailblazer but it is 2 stroke thanks and i still need help quick please
Old May 3, 2008 | 12:31 PM
mabmadman's Avatar
You need to check your engine compression. If it is low, it will not start. Compression brand new should be 120psi. If it is below 90 psi - you will never get it to start.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
cbcole02
Sep 7, 2015 06:16 AM
Dabears1983
Jun 16, 2015 12:17 PM
1000gade
May 27, 2015 12:37 PM
