front clutch spring
Old May 4, 2008 | 10:32 PM
trybaj17's Avatar
Default front clutch spring
how do i change the front clutch spring? i got a new one from RCR in the stage 1 kit and was wondering how to take the old one out and put the new black and white spring in. do i need to pull the clutch off, or can i change it with the clutch still on the quad?
Old May 4, 2008 | 11:33 PM
ftwflh's Avatar
Take the center bolt out the take the 6 smaller bolts out.replace spring,line up the Xs on both parts,start center bolt enough to get the 6 smaller ones started,torque the 6 bots to a tad less than 20 lbs and the center bolt to 40 lbs
Old May 5, 2008 | 02:03 AM
trybaj17's Avatar
do i need a clutch puller tool to take the clutch off?
Old May 5, 2008 | 02:33 AM
contentsunderpressur's Avatar
No, your just taking the plate off the front of it.
Old May 5, 2008 | 07:21 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would also check the weights and pins, and bushing for essive wear while its apart and clean it as well. just a thought.
Old May 5, 2008 | 03:22 PM
trybaj17's Avatar
what do i check for when im looking at the weights and bushings? what do i use to clean the clutch with? compressed air? or is there a specific kind of cleaner that is needed?
Old May 5, 2008 | 04:37 PM
atv gooroo's Avatar
I just put the same spring in mine last week. Take the clutch cover off; take belt off; take a marker and mark the cover to the clutch for the clutch is balanced and you want to put it back the way it was; Take of the middle bolt; (put something through the clutch to hold it)take off the 6 outer bolts; cover comes off and pull the spring out; put in new spring; reverse steps. Clean with compressed air. Just look and make sure nothing broke or worn.
Old May 5, 2008 | 05:05 PM
trybaj17's Avatar
thanks i will do this when i get home on wed. atv gooroo how do u like the new clutch sping?
Old May 6, 2008 | 11:58 AM
atv gooroo's Avatar
I love it. You will notice that it takes a little more rev to get it moving but you get use to it. I can stand it up pretty easy and I don't have to put it in low to get up those short hills or to hop logs. I love the new power.
Old May 8, 2008 | 07:26 PM
MECHANIKE's Avatar
do you happen to know the rates on your spring?
