MAGNUM 4X4 PROBLEM
Old May 5, 2008 | 11:02 PM
2FAST4URASS's Avatar
Default MAGNUM 4X4 PROBLEM
I have a 425 magnum 1995 and the AWD WORKED PERFECT but I just had to take apart the front to grease all the bearing's then before I even ride it I find out you cant use grease ya have to use synthetic hub lube ok take all back apart and soak it in gas and hand clean each part get the lube and put all back togather but will not work what did I do??????? I put it all back togather rite im know I can tighten up the middle nut tight and make it work a little VERRY LITTLE AS IN NOT WORK BUT YOU CAN PUT IT UP ON STAND'S IT WILL TURN THE FRONT A little BUT YOU CAN HOLD THE TIRE BACK WITH YOUR HAND!!! sooo SOMEONE PLEASEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE PLEASEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE PLEASEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE E HELP ME IM AT MY WIT'S END...[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old May 6, 2008 | 07:55 AM
ftwflh's Avatar
Take it back apart and clean the magnet and plate with contact cleaner and then reassemble and torque to specs(you really need a manual on this job)
Old May 6, 2008 | 11:39 AM
MECHANIKE's Avatar
yeah i f you had gear oil,clean it well,torque nut properly,i know a test procedure to test when you come on line........
Old May 9, 2008 | 09:21 PM
MECHANIKE I got it all clean and back togather and rite fluid in but still will not work?? wth lol this thing has me ready to jump off a bridge or push it off one!!! lol and as I said before it all worked perfect before I thought I was doing good by greasing it when putting it back togather do I line up the armerlet plate up with the 3 notches it fits in or no? anyone please help im am stressed to the MAX.
Old May 10, 2008 | 09:06 AM
MaineWheeler's Avatar
I was having problems with mine and after getting it all CORRECTLY back together it still did the same thing, for some reason just hand cleaning it just did not work so I put some atf fluid in and ran it in and out of 4wheel drive for a few miles and drained it and then added more atf fluid----did it 4 times to "clean" the hub out, then the last time I put the proper amount of Polaris On Demand fluid in and its been good ever since. For some reason just hand cleaning it just did not work.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
hondarider1234
Jul 21, 2015 11:53 PM
jettman
Jul 6, 2015 12:16 PM
