Wheel and Tire Help!!!
Old May 7, 2008 | 05:51 PM
WFO_Warrior's Avatar
Default Wheel and Tire Help!!!
Well I have a 03 Warrior and I picked up some new wheels and tires, which are 18x10-8. And with those bolted up, it is lower in the back because of the smaller rears. My question is what do I need to make it look right up front? Didnt know if you guys ran the same size then you can tell me what I need to do in the front.
Thanks in advance, Josh
Old May 7, 2008 | 08:41 PM
horhay's Avatar
get the maxis razor 19x6-10 on the front
Old May 7, 2008 | 10:00 PM
Is that what you run?<div class="FTQUOTE"><begin quote>Originally posted by: horhay
get the maxis razor 19x6-10 on the front</end quote></div>
Old May 8, 2008 | 12:18 AM
Raptor450's Avatar
You're going to have a lowrider.
Old May 8, 2008 | 11:59 PM
Isnt that what the mx guys usually run though? Tire wise.
Old May 9, 2008 | 12:33 PM
pmcc37's Avatar
http://www.diamondjcustoms.com/new/index.htm
they make a lowering kit for the front if you want to run stock 21's up front...
Old May 9, 2008 | 04:01 PM
Raptor450's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: WFO_Warrior
Isnt that what the mx guys usually run though? Tire wise.</end quote></div>
Yeah, but you aren't going to mx your Warrior are you? Most sport trail bikes run 21's up front and 20-22's in the rear for extra ground clearance.
DFWSRT8
Aug 20, 2015 09:24 AM
Cantbuytime
Aug 17, 2015 06:33 PM
Jul 24, 2015 11:57 AM
rcappie4
Jul 18, 2015 07:51 AM
