How do I remove axle?
Old May 9, 2008 | 10:58 AM
Wild Bill's Avatar
Default How do I remove axle?
I have 2004 sportsman 4x4. How do I remove the right front axle from the differential? I have taken every bolt out of the diff and it does not seperate to remove the c clip. It seems the right and left axles are connected internally. When i pull on the right the left moves and stops the right from coming out.
Old May 9, 2008 | 11:54 AM
MECHANIKE's Avatar
wildbill call service at the dealer, i have a scram 4x4+it takes arealhardtug to remove.fast,sudden+hard(thats what she said).
Old May 9, 2008 | 12:12 PM
Wild Bill's Avatar
Are you saying don't attempt, it's too difficult. And just take it in to the dealer. I had a feeling looking at the clip on the replacement axle that that was the only way to remove.
Old May 9, 2008 | 02:06 PM
MECHANIKE's Avatar
no what i'm saying is talk to service to see if its the same as mine,mine i ended up grabbing it with both hands+ put both feet on the machine+pulling hard+sharp like i'm pull starting a huey helicopter.does it have a circlip?which is a wire wrapped around a groove in the shaft.
Old May 9, 2008 | 02:26 PM
Wild Bill's Avatar
yes it has the round (opposed to flat) clip on the shaft. I just spoke to service and he says the same . Twist it a little to find a point where it seems to be at its farestmost towards the outside and then give it a good yank and it should come out. And I better bolt that sucker back together before yanking on it like a wildman. Ehhh? And thanks "Mechanike" for responding to my situation. Safe riding to you.
Old May 9, 2008 | 04:06 PM
MECHANIKE's Avatar
10/4 on boltin it back togather so you don't mess with the seals,anytime w.b.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
bmark0610
Sep 7, 2015 09:42 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Jason Richards
Sep 4, 2015 06:17 PM
snowolson
Aug 31, 2015 03:51 PM
