Xplorer 500 Dies When Put Into Reverse/ FIXED IT. THANKS
Old May 15, 2008 | 10:40 PM
Preach's Avatar
Default Xplorer 500 Dies When Put Into Reverse/ FIXED IT. THANKS
My 97 Xplorer 500 would not go into reverse this afternoon and keep running. I figure it is a safety switch issue, but that is only a guess. Thanks for any help you can give me.
Old May 15, 2008 | 11:08 PM
ftwflh's Avatar
THe reverse limiter is bad.You can bypass it by unplugging the blk wire from the box.
Old May 15, 2008 | 11:47 PM
Preach's Avatar
Thanks for your response. I have mechanical skills, but I am not sure I know what "box" you are referring to. Also, when you say "bypass" and you refer to "unplugging' the black wire... are we talking about splicing it in on the other side of the "box". Thanks
Old May 16, 2008 | 09:32 AM
Ujoint's Avatar
You are going to have to open the "hood" (where you fill the radiator) and mounted on the left side of the panel in front of the steering bar is a black box (not the one with the yellow wires) - this is the RPM limiter (or Rev). Unplugging the black wire (and just leaving it hanging) "bypasses" the signal to the ignition coil to "cut out".
Old May 16, 2008 | 01:14 PM
Preach's Avatar
Thanks Guys!!! I got it.
Polarisman1123
Sep 13, 2015 10:06 AM
house1
Aug 9, 2015 10:49 PM
315blaster
Aug 8, 2015 08:13 PM
Karas3434
Aug 3, 2015 09:17 AM
cornermike
Jul 30, 2015 06:37 AM
