sportsman 700 backfires
Old May 19, 2008 | 01:22 AM
biggfredi's Avatar
Default sportsman 700 backfires
Just bought my first ATV. sportsman 700 it starts and accelerates just fine. but when i decel. it really makes load poping sound thru exhaust. any suggestions on how to fix? THANKS
Old May 19, 2008 | 07:49 PM
SCRAMBLER500XXX's Avatar
HOW MUCH SLACK IS IN THE THROTTLE LEVER, SHOULD ONLY BE ABOUT 1\8 INCH OF FREEPLAY. THERE IS AN ADJUSTER ON THE CABLE, RIGHT BEFORE THE CABLE ENTERS THE HEADLIGHT POD, YOU HAVE TO SLIDE BACK THE RUBBER BOOT AND ADJUST UNTIL THE FREEPLAY IS CORRECT.
GOOD LUCK
Old May 19, 2008 | 07:58 PM
03scrambler500's Avatar
is there aftermarket exhasut on this? if so you could be leaking air into the header. or your mixture screw is to lean and needs to be richend up. but if everything is stock you shouldn't have to mess with this. good luck
Old May 19, 2008 | 08:14 PM
contentsunderpressur's Avatar
What year is it?
Old May 20, 2008 | 06:11 PM
adrenalator's Avatar
Check the intake boot between the carb and engine, there known for cracking and will cause a back fire on decel.
Cliff Yeatman
Advanced Dyno
Old May 20, 2008 | 06:13 PM
check the intake boot between the carb and the engine there known for cracking and causeing a back fire on decel.
Cliff yeatman
Advnaced Dyno
donintennessee
Jan 8, 2021 12:40 PM
COFatboy
May 2, 2020 12:06 AM
donintennessee
Aug 19, 2015 02:22 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
