blaster oil question
Old May 24, 2008 | 11:06 PM
nightmare0098's Avatar
Default blaster oil question
should i clean the oil injector on my blaster? i heard many times that they clog easy and blow the motor.. also i ran it out of oil today and tried to start it a couple of times befor i relized it was out.. how bad is this.. lol(besides needing a new oil sensor =) )
Old May 25, 2008 | 12:53 AM
91Warrior357's Avatar
i dont and never will trust oil injection i block them and mix myself they run better dat way 2
Old May 25, 2008 | 03:45 AM
i know that.
but is it ok to take the injector off and clean it? if so how?
Old May 25, 2008 | 06:59 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
The problem with the pumps on the blasters if I understand it correctly is that they used plastic gears. The gears would become stripped and no properly provide oil.
I'd block it off also. However, it's just a problem with the blaster. I'd trust other auto-lubbers.
Old May 26, 2008 | 12:37 AM
most bikes use plastic motor oil pumps 2 lol i know mine does
Old May 26, 2008 | 06:07 AM
how will i know when it starts to go bad?
Old May 26, 2008 | 09:00 AM
you see thats the problem...its hard too tell matter of fact sometimes u cant...id watch you oil soot on ur pipe, keep the silencer clean so you cud see if there wasnt any oil being ran through ur engine...i dno bout cleaning ur injector, if you know you can do it theres no harm and cleaning it...id just run lucas oils or seafoam through it.
Old May 27, 2008 | 01:22 PM
ok. the onlly spot where oil comes out is where the exhaust bolts to the cylinder.. and thats just a gasket prob roght?
Old May 27, 2008 | 01:25 PM
yea that or a spring worn or missing, but thats kinda normal on alot of 2 strokes if you dont see any more of that oil coming from header or silencer u know that pump aint working...lol but that not a good thing 2 rely on
Old May 27, 2008 | 07:36 PM
kbpope609's Avatar
well i had to have another one myself.I thought i blew up the moter but i didnt. This and blasters are just peices of ****. Beleive me i know i have two blaster!
