more torc
Old May 27, 2008 | 07:49 PM
pulldog500's Avatar
Default more torc
Hi
I have a 1999 sportsman 500 and want to get more torc on take off, also would like it to have a bit more power
What should I be looking at buying?
Old May 27, 2008 | 08:01 PM
quadracer18's Avatar
Default more torc
Pipe!!! Thats going to be a good investment for improved power throughout the power band. Also you can change out your sprocket for more torq at the bottem end. But you'll loose in the top doing that. It just depends on $$$$$ you want invest in your 500
Old May 28, 2008 | 12:50 AM
atv gooroo's Avatar
Default more torc
If it is belt driven you can get a bigger primary spring. Alot of us are doing it and loving it. Search for Ritter Cycles and give him a call, he will hook you up.
Old May 29, 2008 | 06:50 PM
pulldog500's Avatar
Default more torc
thanks guys
Old May 29, 2008 | 07:49 PM
user493's Avatar
Moto Psycho
Default more torc
<div class="FTQUOTE"><begin quote>Originally posted by: quadracer18
Pipe!!! Thats going to be a good investment for improved power throughout the power band. Also you can change out your sprocket for more torq at the bottem end. But you'll loose in the top doing that. It just depends on $$$$$ you want invest in your 500</end quote></div>
What sprocket?
Most pipes only give you a <u>slight advantage</u> overall, or are good only at a certain fraction of the power curve and are <u>worse overall</u>. They SOUND like they're making a lot of power, but most aren't worth the price unless you are doing other mods too, like re-jetting the carb.
A clutch kit will give you what you want. There are several to choose from. Many come with better quality weights than stock too. Some even have a new helix with different angles. It all depends on how much you want to spend, but the clutch is the only logical place to start.
Old May 30, 2008 | 11:17 AM
pulldog500's Avatar
Default more torc
Thanks
I was thinking about putting a clutch kit it, but I don't know what one is good for what I'm looking for. Does anyone know any good sites? Or anywhere in Canada?
Old May 30, 2008 | 11:55 PM
user493's Avatar
Moto Psycho
Default more torc
Google "Polaris ATV clutch kits" or "Heel Clicker" or just cut and paste any of these addresses.
www.erlandsonperformance.com
www.daltonindustries.com
www.rittercycle.com
www.hotseatperformance.com
Old May 31, 2008 | 11:09 AM
Kerbbirds's Avatar
Default more torc
The Dalton kit is a good kit,
Old Jun 3, 2008 | 07:15 PM
pulldog500's Avatar
Default more torc
thanks guys
Old Jun 3, 2008 | 08:02 PM
itstillruns's Avatar
Default more torc
if a 800 Sp intake will fit install that w/ k&n filter and a LRDtorq muffler and jet kit it should burn some rubber
