yamaha raptor 660 backfiring
Old May 31, 2008 | 05:36 PM
01yamaha660's Avatar
Default yamaha raptor 660 backfiring
i have been having some problems with my raptor. lately in bout second gear and up when i try to get on it it bogs down and almost dies. then if i decel it backfires like crazy and dies. i took it somewhere but the guy didnt fix it at all. all he did was cut a hole in the top of my airbox and thats when it started backfiring real bad. any ideas
Old May 31, 2008 | 05:41 PM
actually let me refraise myself from bout second gear and up ill shift and it starts out fine but once the rpms get high it bogs down and almost dies
Old Jun 1, 2008 | 02:46 AM
91Warrior357's Avatar
bigger mainjet, new plug, raise needle, make sure carbs are in sync and clean,
Old Jun 1, 2008 | 11:29 PM
one of my bolts is busted on my exhaust where its attatched to the header. could that be part of the reason. i was reading somewhere that sometimes if ther is an exhaust leak that it will cause it to backfire
Old Jun 2, 2008 | 10:46 PM
DollarBillz's Avatar
does it only do it when you hit about 1500 rpm's if so it sound's like your reverse sensor is bad
Old Jun 3, 2008 | 11:43 AM
ya where is the sensor at
Old Jun 3, 2008 | 07:29 PM
there are two sensor's down buy the gear shifter one is for the neutral and one is for the reverse all you have to do is cut the wire and ground the wire from the cdi
Old Jun 4, 2008 | 10:37 PM
so i ground it to the what, whats the cdi
Old Jun 4, 2008 | 11:33 PM
habitatjoiskater's Avatar
whats the cdi haha. its by your battery more towards the back. it hooks all your wires.
but anyway could this be a problem with mine because i thought it was the jetting and i still havent jetted it but the reverse light blinks on when i shake the wheeler or drive it.
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
black_thunder
Jul 12, 2015 11:04 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
