cv joint to bearing carrier
Old Jun 5, 2008 | 08:10 PM
snowmann's Avatar
Default cv joint to bearing carrier
after removing the upper and lower A-Arm bolts will the bearing carrier slide out...i have to replace my rear wheel bearings and am really nervous about it..please advise
Old Jun 5, 2008 | 08:14 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
are you talking about this?
Old Jun 5, 2008 | 08:16 PM
snowmann's Avatar
yes, exactly, it seems all you need to do is slide the bearing carrier off the axle at this point...am i wrong?
Old Jun 5, 2008 | 08:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
that sis correct as you see in the pic im just sliding it off. now the bearing are a differnt story and can be a real pain in the a$$ to chaanhe w/out a press.
Old Jun 5, 2008 | 08:24 PM
snowmann's Avatar
Thank you so much ...you ROCK....and yeah i am briniging the carrier to a garage to have the old ones pressed out and the new ones pressed in...i feel confident now...before i was not sure how the cv/carrier assembly came apart...if there was a snap ring or something, but i guess it is just held in by the hub nut...thank you so much again
Old Jun 6, 2008 | 09:04 AM
JAMIEZ71's Avatar
I got a feeling I'll be doing this when i replace the seals on the rear of my sportsman while I'm at it.
Old Jun 7, 2008 | 03:59 AM
itstillruns's Avatar
ya know if you heat the carrier w/torch the bearings pretty much fall out. put new bearings in freezer for a few hours and the drop right in.
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
