cam shaft question
Old Jun 8, 2008 | 01:28 PM
pwoens's Avatar
Default cam shaft question
what is the best way to determine you need to replace your cam shaft? I visually inspected mine yesterday and it is smooth until you see the lobes....the lobes appear to be a little rougher then the rest of the shaft and there were a few shavings on the side of the lobes?
current problem with sportsman 500....takes a long time to start, bakfires when given throttle during starting attempt and spits out a mist of gas in air box, if/when it starts you can not go faster then a slow walk or it bogs out.
talked to previous owner last night and he said the "kids" said it started to run rough the last couple of times they rode it.
And if it is cam shaft...whats the best place to buy from. Bike Bandit has it for $220 ??
thanks again for all your insight and help
Old Jun 8, 2008 | 03:21 PM
drlang's Avatar
Sure sounds like a worn exhaust lobe to me. Along with the cam make sure you install a new cam follower for the exhaust side. As far as prices I don't know, give RCR a shot. If he can't do it he will get you going in the right direction. Doc
Old Jun 9, 2008 | 01:02 AM
pwoens's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: drlang
Sure sounds like a worn exhaust lobe to me. Along with the cam make sure you install a new cam follower for the exhaust side. As far as prices I don't know, give RCR a shot. If he can't do it he will get you going in the right direction. Doc</end quote></div>
Sorry for my ignorance...who is RCR ... any contact info??
thanks
Old Jun 10, 2008 | 07:02 AM
user493's Avatar
Moto Psycho
<div class="FTQUOTE"><begin quote>Originally posted by: pwoens
thanks</end quote></div>
Ritter Cycle Racing. http://www.rittercycle.com/
Old Jun 10, 2008 | 09:34 AM
Ujoint's Avatar
The camshaft and exhaust rocker arm are not high profit items, so finding it much less than the $220 ( about $30 over dealer cost) and $60 for the exhaust rocker arm ( about $10 over dealer cost) is going to be hard. Normally at least 1/3 of the price of a part is dealer profit......
Old Jun 10, 2008 | 06:29 PM
MagnumPO's Avatar
I have had good luck on ebay, occasionally someone will be parting out a quad real similar if not the same. good luck
1ArmBandit
55
Oct 14, 2015 09:03 PM
cornermike
Sep 10, 2015 08:30 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Bigtwin700
Sep 9, 2015 09:32 AM
Rooky
Sep 9, 2015 03:16 AM
