Trx450r Rev Box?
Old Jun 9, 2008 | 02:33 PM
jkenosky88's Avatar
Default Trx450r Rev Box?
i want to get a rev box for my 05 Honda Trx450r. At Motosport there are two i was lookin at.
http://www.motosport.com/offro...dId=925047&nav=&sMMY=
or
http://www.motosport.com/offro...dId=925039&nav=&sMMY=
What is the difference between the 2? Is it worth the extra money for the more expensive one? Will one of these make me go alot faster?
Thanks
Old Jun 9, 2008 | 03:57 PM
DWill58's Avatar
I'm not a fan of Big Gun, but they will make a noticeable difference on the Top End because it raises the Rev Limiter and it also advances the timing to add a little more power at mid-high range. The difference between the two is the timing curve and the higher RPM's by the second one (hi-rev). Which allows for you to wind out the gears more and acheive a broader power band than the cheaper one. I personally went with the DynaTek box ($175), and noticed a significant difference, but I also did all of my motor work as well to go with it, so I had a drastic increase in power and a higher rev limit as well. I also do not recommend the Hi-Rev box unless you are going to make some other improvements internally (a cam, jetting, aftermarket full pipe, port and polish, something along those lines).
01ssls1
Sep 22, 2015 06:50 AM
Aug 5, 2015 02:10 AM
yambam13
Jul 4, 2015 01:49 PM
dorene
Jun 5, 2015 05:25 PM
CyberTrip2003
Sep 12, 2003 10:53 PM
