Praire Issue
Old Jun 12, 2008 | 06:56 PM
Renegade44's Avatar
Default Praire Issue
I have an 06 Praire and the issue was that I bought it and let it site for like 2 years. recently I brought it out to use it finally and it needed to get charged. I charged the battery and it started up but once I let it idle or turn off, that battery was dead again. I chaged the battery andcharged it for 24 hrs. now when I go to start it it will only idle real low and then stall out. If I press the gas it stalls no matter what. anyone have any clue how to fix this?
Old Jun 13, 2008 | 04:45 PM
Hayashi's Avatar
> Clean carbs which is partially clogged up with dried up old gas.
> Replace old fuel with fresh one.
> Replace old battery which has lots its full capacity.
Old Jun 16, 2008 | 01:28 AM
Renegade44's Avatar
I replaced the battery and drained the fuel out, put in new gas and some engine cleaner and nothing changed. still acts the same way.
I think maybe there might be a throittle issue. could a throttle problem cause it to act this way?
Old Jun 17, 2008 | 11:54 AM
Hayashi's Avatar
Sounds like you may have two issues.
> Clogged pilot jets in your twin carbs.
> Battery driaining or charging problem. Check amp draw rate and check stator and voltage reg/rectifier.
Get a manual if you would do the work by yourself.
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
WesTech
11
Aug 11, 2015 07:55 AM
Unzzy66
Jul 11, 2015 10:01 PM
