Serd15
Old Jun 13, 2008 | 09:37 PM
MagnumPO's Avatar
Default Serd15
what does that mean? I cant tell if the S is a S or a 5 but the rest is accurate. This is on the bottom of my speedometer (it doesnt work) I cant find the origin of this code, the nearest I can tell is that it means the flip over protection is not working. Anyway I'm sure someone knows what it may be.
Thanks
Old Jun 13, 2008 | 09:41 PM
user493's Avatar
Moto Psycho
Default Serd15
I Googled it and the best answer I found was to disconnect the battery for a minute to see if the computer resets.
Old Jun 13, 2008 | 09:44 PM
MagnumPO's Avatar
Default Serd15
I appreciate it but I had the battery disconnected for about 3 months. the code was up before and after. I dont really care I have changed the fluids and all that many times and taken pretty good care of it. I'm sure its like a car with the check engine light on. I checked, it was still there.
Old Jun 13, 2008 | 09:51 PM
user493's Avatar
Moto Psycho
Default Serd15
What year and model is it? Do you have the manual? Is the wrench icon or "check engine" on? I can't find any code like that in the manual for my quad, just the blink codes.
I found something else that says to check the speed sensor that goes to the right front hub. The sensor counts the holes in the brake disc to calculate the speed. The problem might be there. Also some people are having 4x4 and speedo problems together. Does 4x4 work, if you have a 4x4?
Old Jun 13, 2008 | 10:59 PM
MagnumPO's Avatar
Default Serd15
4x4 is good, speedometer dosent work, never has. thats probably it. no wrench icon. it is a 2000 magnum 500. I have a service manual but dont see this code in it. Thanks for looking.
Old Jun 14, 2008 | 01:02 AM
user493's Avatar
Moto Psycho
Default Serd15
Yeah, I tried Magnum. I guess your SERDometer only goes up to 15. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 14, 2008 | 06:56 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Serd15
as long as the awd works your doingbetter then some. it might be a sensor for the speed. gone bad or maybe rpm? just guessing though.
Pepete
Dec 2, 2005 10:43 PM
