safty issue
Old Jun 16, 2008 | 07:06 PM
200es's Avatar
Default safty issue
ok not sure where to start on this one, i have a 98 500 scrambler 4x4, sometimes when going in a straight line at high or low speeds it will suddenly pull hard to the left or right, first time it happend i was going full speed on pavement when it pulled to the right and i hit a tree, if anyone could PLEASE give me any info at all why this is happening it would be great
Old Jun 16, 2008 | 08:13 PM
miniexcavator's Avatar
Default safty issue
sounds like your hubs are engaging. I'm not really familiar with your atv but if it has wet hubs when was the last time you changed the fluid?
Old Jun 16, 2008 | 08:23 PM
200es's Avatar
Default safty issue
i just bought this atv, so not sure when it was last changed. i noticed to that the iner cv joints are really bad, would they cause this? i don't really think it would seeing as how it is in 2 wheel drive, but i don't know much about it
Old Jun 16, 2008 | 09:09 PM
Default safty issue
sometimes it dosn't matter if your in 2 wheel. what do you mean by cv's are bad...........try a search of this site about your problem i'm sure its been discussed before
Old Jun 17, 2008 | 01:28 PM
200es's Avatar
Default safty issue
the joints on the axle are bad, i read on here somewhere that there is some kind of fluid you can put in the hubs to clean them first before you put the hub fluid in. is this true?
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
WesTech
11
Aug 11, 2015 07:55 AM
Unzzy66
Jul 11, 2015 10:01 PM
