Help replacing lower a-arm
Old Jun 16, 2008 | 08:54 PM
EastCoastWest's Avatar
Default Help replacing lower a-arm
Not real familiar with this but I'm replacing the lower right a-arm on my 2003 Kodiak 450. Just wondering if there is a trick to get the a-arm separated from the lower ball joint. Silly me thought it would just drop right off once the castle nut was off.
Old Jun 16, 2008 | 11:09 PM
Doctorturbo's Avatar
GOT BOOST!
If I understand you correctly, a small pickle fork will do the job you want to do.
Sometimes I have turned the nut around and thread it so it is flush with the ball joint stud and wail away at it with a 5 pounder.
You will not be able to save the ball joint if you do this though.
Old Jun 17, 2008 | 11:13 AM
I would have thought that the fork would damage the rubber seal....
I also considered fliping the nut over, if I take the ball joint out of the knuckle and put it on my bench vice with the vice open enough so that the ball joint just hangs and the old a-arm rests on the vice I can't see how the ball joint would be damaged.
Old Jun 17, 2008 | 09:01 PM
GOT BOOST!
<div class="FTQUOTE"><begin quote>I would have thought that the fork would damage the rubber seal.... </end quote></div>
It does.............at least most of the time it does.
Most of the time the ball joint is ruined. Most of the time those things are REALLY in there!!!!!! And I do mean REALLY!!!!
Took one out of a car a few months back and I REALLY had to wack it with a 5 pounder to get it out. I tried the nut trick first but no go. Sometimes it takes an act of God to get those things out.
Old Jun 18, 2008 | 08:42 AM
Nice...
Old Jun 23, 2008 | 02:23 AM
alfire166's Avatar
I have a fork attachment for my pnuematic chisel that works well. I have used it several times and not damaged the rubber bad enough that I couldn't reuse it. Good luck, they can be pretty tough sometimes.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Jul 28, 2015 01:58 PM
trouttracker
Jul 20, 2015 11:54 AM
musselmark
Jul 17, 2015 02:40 PM
jettman
Jul 6, 2015 12:16 PM
