scrambler 500 4x4 problems
Old Jun 19, 2008 | 09:06 PM
nick9882's Avatar
Default scrambler 500 4x4 problems
i just got a 2000 scrambler 500 4x4,this is the first polaris ive owned and dont know alot about them,here is the problem im having,if i put it up on a jack and put it in forward and hit the gas it wil;l kick into 4 wheel drive even though the switch is not in 4x4 position and only the right tire will spin when in 4x4,any help would be great.
Old Jun 19, 2008 | 09:20 PM
ftwflh's Avatar
Change the hub fluids......better yet service the whole thing.
Old Jun 19, 2008 | 10:05 PM
nick9882's Avatar
not really sure on how to change the hub fluid,this is the first atv ive had that has push button 4x4,should it be dry around the hub,where the cv axle meets the hub on the rubber boot it is all oily.
Old Jun 19, 2008 | 10:10 PM
ftwflh's Avatar
It should be dry.You really need to get a manual and go over this quad close and fix EVERYTHING before it starts to $$$$$$ you to death.
To check the hub fluid there is a allen head screw on the hubs.Take it out at 12 oclock.Turn wheel to 3 or 9 oclock you should get fluid running out.If not add type F tranny fluid or Polaris ON DEMAND HUB FLUID.
Once you get everything right you will get years of fun out of this.But remember a Polaris is a high maintanence machine.You have to service them regularlly.
Old Jun 19, 2008 | 10:18 PM
nick9882's Avatar
thanks,ill give it a try and hopfully that is it and it is a easy fix,will definetly have to get a manual for it,also any suggestion on why the cooling fan wouldnt kick on.
Old Jun 19, 2008 | 10:38 PM
ftwflh's Avatar
Fan.....either you didnt get it hot enough or one of the sensors is bad or even the fan could be bad.A manual will tell you how to test each one
Old Jun 19, 2008 | 11:18 PM
nick9882's Avatar
just went out and checked the oil,i pulled the allen bolt ot and turned the hub upside down,with the hole facing the ground and nothing came out,i am guessing that this would be my problem,anyone know how much oil to put in
Old Jun 19, 2008 | 11:20 PM
ftwflh's Avatar
Fill it until it comes out with the hole at 9 oclock
Old Jun 19, 2008 | 11:30 PM
nick9882's Avatar
thanks
Old Jun 21, 2008 | 02:02 AM
[img]i/expressions/face-icon-small-happy.gif[/img] When only one wheel is spinning ,your armature plate has become permantely magnetized allowing hilliard to engage even out of awd! Pull hub assy and replace plate(probably sticks to coil) Over 20 years have changed dozens! While at it check/replace hub and strut seals! Hope this helps
