What's an offset for rims??
Old Jun 22, 2008 | 08:45 PM
KawiMojave's Avatar
Default What's an offset for rims??
Hello, I was wondering what the offset for a rim is. For example,
T154141 Polish 10 x 5 4+1
T154142 Polish 10 x 5 3+2
T154142B Black 10 x 5 3+2
154144 Polish 10 x 5 2+3
T154152 Polish 10 x 5 3+2
T154152B Black 10 x 5 3+2
T154156 Polish 10 x 5 2+3
The forth column to the right is the offset column and i have no idea what that means. Do you....... Any help would be appreciated!
Old Jun 26, 2008 | 08:46 PM
esonnen's Avatar
If a rim does not have an offset, the part where it mounts to the hub is centered (neither left or right). Your stock Mojave rear rims for example have are 10 x 8 3+5 This means that your rims are 8 inches wide and the mounting surface is 5 inches from the outside and 3 inches from the inside. (if you look at your rim you will see what I mean) The mounting surface is shifted one inch torward the inside from a 4+4 to a 3+5). If you go to rockymountainatv.com you can enter the year and make/model of your machine and it will tell you what it has available for your atv. you have a 4/155 bolt pattern. your front rims are 10 x 5 3+2. I hope this clears it up for you.
fd24
Jan 16, 2019 08:59 AM
badgerboy1
Sep 26, 2017 06:11 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
Jason Campbell
Sep 7, 2015 02:25 PM
