blaster oil squirting
Old Jul 2, 2008 | 05:35 PM
nightmare0098's Avatar
Default blaster oil squirting
there is a hose under my nose plastic that is pouring and spraying oil when it heats up i have no clue what the problem is any suggestions?
Old Jul 2, 2008 | 05:56 PM
91Warrior357's Avatar
too much oil in the gearbox
Old Jul 2, 2008 | 06:05 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Is that a safe way to tell? I have one that leaks but, no way to know how much to add.
Old Jul 2, 2008 | 06:10 PM
i havnt filled it in so long and after i filled it there wasnt any leaks. and i ride like every day
Old Jul 2, 2008 | 09:36 PM
whitford_b's Avatar
where does yours leak oil at cause mine does really bad and i cant find out where its coming from
Old Jul 2, 2008 | 10:41 PM
its coming out of an overflow/air hose under the nose plastic. the hose connects all the way to the right side of the motor .
(right side if your sitting on it)
Old Jul 3, 2008 | 07:22 AM
hotblooded's Avatar
Dumb question but make sure your oil injection line is hook up, I had a freind that took the line off to take carb off and put it out of the way up there and forgot to hook it up. That will spray oil. I would think that the case oil should spray down or at least that is where my vent line is. You could also make sure that you shocks are blown out too.
Old Jul 3, 2008 | 07:23 AM
hotblooded's Avatar
Oh one thing that I forgot that should be checked is the hydrualic brake lines, if it is clear oil that is your problem.
Old Jul 3, 2008 | 10:05 AM
Koopa's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: whitford_b
where does yours leak oil at cause mine does really bad and i cant find out where its coming from</end quote></div>
We split the case to fix a trans problem. leaked ever since. : /
Anyone know how I tell how much to add? There is no sight glass or dip stick.
Old Jul 3, 2008 | 12:49 PM
i havnt taken my carb off so it should still be attactched. and also i have a 02 so i dont have hydraulic brakes..
