Cooling Fan never comes on
Old Jul 3, 2008 | 01:21 AM
sniperj78's Avatar
Default Cooling Fan never comes on
Hey fellow Kawasaki fans,
I have an '07 650 Brute Force with 57 hours on it, 571KMs. I was out with it this past long weekend with an '03 650 Prairie and a Suzuki (not sure what model). We drove hard all weekend and even climbed up a trail near the Oldman River campground to a height of at least 1000 feet. Not once did my cooling fan come on when I figured that it should have considering the rides we did and the temperature (+30 4 days straight). The other two quads' fans came on quite a bit when we would stop for a beer which I know is normal. We did notice though that my fan never came on, not once. I wasn't overly concerned because the coolant temperature warning light never came on.
I'm just wondering if this is normal?? Is it possible that even after a four hour ride up a mountain in 32 degree heat the fan did not need to turn on? even once? or is it now totally quiet on the '07+ models unlike the '03 Prairie's fan that whines for 30-40 seconds after shutting off the quad?
Old Jul 3, 2008 | 09:12 PM
kawimudslinger's Avatar
i would say its normal, my mojave fan has never came on since i have owned it, i thought it was odd too but, a local mechanic told me they only come on when they need to, i was skeptical myself but it runs fine so im not going to worry about it.
Old Aug 15, 2008 | 10:36 PM
player9772's Avatar
Default Cooling Fan never comes on"></title><script src=
i had alot of problems with mine, the circuit breaker under the seat would always lose connection and the fan wouldnt work and one time the wire going to the switch that turns on th high temp switch was broken and didnt tell me that it was running hot until the coolant started boiling out of the overflow bottle. another thing it could be is the switch on the radiator not connecting the circuit and turning the fan on, disconnect the two wires and touch them together, the fan should come on. if it doesnt check the circuit breaker. i replaced me circuit breaker with one i picked up at my auto parts store.
Old Aug 16, 2008 | 02:28 PM
Todger's Avatar
I don't think it is normal.. I would check the connection on the temp switch located on the radiator. It would be non-throttle side of the machine on back side of the radiator. If it is a 650 SRA, you need to remove the plastic inside of wheel. I bet the crimp is bad on the wire and the switch is disconnected
TK
Old Aug 17, 2008 | 07:33 PM
cadillacdude1975's Avatar
do you have a manual that tells you what temp the fan is supposed to come on at? hell i would bypass that stupid switch and toggle switch the fan if it were mine.
Old Aug 25, 2008 | 01:30 AM
chevytrkn1's Avatar
My connector uncer my seat also has caused me problems, I ended up black taping it real tight and it has not quite working anymore
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
