2003 Honda Rancher ES not downshifting?
Old Jul 7, 2008 | 10:51 PM
5.0stang's Avatar
Default 2003 Honda Rancher ES not downshifting?
I recently drove a 2003 Honda Rancher ES and at times it would not downshift. I had to turn the engine/key to off and turn the key back to accessory to get the gears to change down, one at a time.
Any ideas what this could be?
What size did the 2003 Rancher ES's come as (350 cc)?
Old Jul 8, 2008 | 07:33 PM
5.0stang's Avatar
Anyone have an idea?
Old Jul 8, 2008 | 08:38 PM
HondaMechanic's Avatar
The gear position indicator should have flashed a code ...
Old Jul 8, 2008 | 08:41 PM
Yes the 2003 was a 350 ... 2000-06 all had the 350 engine ..
Old Jul 8, 2008 | 11:09 PM
5.0stang's Avatar
How does the flashing occur?
flash - flash - flash = 3
....pause....
flash - flash = 2
Code is 32?
I will check what it is next time.
Is there a list I can cross reference once I get the flashing code?
Old Jul 9, 2008 | 07:45 AM
The first set of flashes will be the new code the second set will be an older code .. I would erase the codes and re-test the bike , to erase the codes while the error code/s are flashing just push the up/down buttons at the same time and hold then pushed for about 3 seconds ..
Code 3 is angle sensor ..
Code 2 is up/down shift switches ..
Old Jul 9, 2008 | 01:03 PM
5.0stang's Avatar
I was just giving an example.
Thanks for the tips and I will check it out!
bigred20653
Aug 31, 2015 12:41 PM
bradco
Aug 21, 2015 08:11 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Scottma518
Jul 16, 2015 09:19 PM
Scottma518
Jul 10, 2015 12:42 AM
