engine smokes, bad
Old Jul 14, 2008 | 04:35 PM
1989250moto4's Avatar
Default engine smokes, bad
my bike smokes really bad, i have to put half a quart of oil through it a day. can i change the rings without changing the piston? or will it self destruct?
Old Jul 14, 2008 | 10:49 PM
Doctorturbo's Avatar
GOT BOOST!
Not likely if it is using that much oil. The rings arn't the only things that wear. The bore and piston also catch hell.
Old Jul 14, 2008 | 11:21 PM
warhorse20000's Avatar
engines im fermilur with , just not so much in bikes..(cars/sleds mainly) so this may work but may not for you !
#1 i would try getting at the valves , remove what ever cover you have.
In the valve cover where the oil runs in the holes , i would take a real fine wire and polk the holes , eg: make sure no not plug`d up , as oil than if pluged up would than seep itsway into the ports and cause your massive smoke / oil burn problem.
or
#2 try putting in a 1/2 quart of desil fuel or stove oil (tranny oil works 2 just not as good) (dont drain all old oil first add to it, drain some out if nessasry but not all)
in your crankcase and go for a ride , it should clean out any sludge /carbon exc.. than change your oil, sometimes that works as well.
or
#3 check valves and or do a valve job
or
#4 replace rings.
Any of thies may work for you.
And the top 1 or 2 sugestions could save you alot of money in repairs.
Old Jul 15, 2008 | 12:45 AM
i've heard of people putting desiel fuel in their cars to clean them out but they put it in the gas tank not the crankcase
dirt ryder
Sep 27, 2015 09:22 PM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
Dirtbikemike1
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
