loose steering and vibration
Old Jul 15, 2008 | 02:51 PM
whitford_b's Avatar
Default loose steering and vibration
my yamaha blaster is awful shaky in the steering and im wondering what i should be doing about it any help would be great.
Old Jul 16, 2008 | 03:19 PM
cadillacdude1975's Avatar
this could be any number of things. a bent rim, a sticking caliper, out of balance rotor, alot of mud packed in the rim, bad tie rod, bent steering arm from landing too hard after a jump, bad ball joint, a tire that has started to break apart, loose wheel, loose a-arm or a-arm bushings damaged/missing, handlebars could also be loose, etc. the list goes on and on. id check the rim for mud first, then take the wheel off and clean both the front brakes. from there you can check the balljoints and tie rod ends and a-arms as well. have you hit anything hard recently? that could bend a few things.
Old Jul 16, 2008 | 09:21 PM
whitford_b's Avatar
no never hit anything thats why im wonderin but i think its in the steering column
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
