why is it doing this
Old Jul 25, 2008 | 02:34 AM
asdfgh1's Avatar
Default why is it doing this
Hey i have a 1982 hond 3 wheller and i just got new top end gaskets it runs great but smokes and every now and then it will bog out and die then it will start right back up and run fine why dose it do that?
ANY HELP WILL BE APPRICIATED
THANKS
Old Jul 25, 2008 | 07:00 AM
HondaMechanic's Avatar
What model .. If it is the 185 or 200 then I would check the fuel tank vent (on the gas cap) if they get a bump then they won't let air in the fuel tank .. They are easy to fix..
To check it does the "T" valve lever raise and lower when you open and close the vent...
Old Jul 26, 2008 | 02:42 AM
asdfgh1's Avatar
Its is a plastic gas tank but i found the problem it had a short in one of the wires and now it is fixed and ready to ride thanks for da help anyway.
