PRAIRIE CVT
Old Jul 28, 2008 | 09:06 PM
2FAST4URASS's Avatar
Default PRAIRIE CVT
I bought a 1999 PRAIRIE 300 a few months back it had carb issues and every bearing in the rear-end was bad so after $550 in part's she's running and im very happy with it ''it run's great but I can tell it wasnt form the rear end it was taken care of 100% so with all this said is there anything in the belt housing that need's to be greased or adjusted any help would be great THANK'S IN ADVANCE Jeremy...
Old Aug 3, 2008 | 02:19 AM
happyjeep's Avatar
Default PRAIRIE CVT
nope. just pull the cover off. wipe it with a dry rag. this will also give you a chance to inspect the belt.
Old Aug 3, 2008 | 11:11 AM
Hayashi's Avatar
Default PRAIRIE CVT
<div class="FTQUOTE"><begin quote>Originally posted by: happyjeep
nope. just pull the cover off. wipe it with a dry rag. this will also give you a chance to inspect the belt.</end quote></div>
That's not quite true.
The driven belt pulley is riding on a bushing and that needs to be cleaned and greased so that sheaves can open and close smoothly. Also, the belt deflection should be cheked/adjusted by removing the shim(s) in the driven pulley.
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
