Raptor Brake Block-Off
Old Jan 27, 2001 | 02:15 AM
lucey's Avatar
Can anyone recommend a good brake block off plate ? How about a perch to replace the stocker ? Also are there many opinions of what to do with microswitches in the stock perch. I keep hearing different opinions.
Old Jan 27, 2001 | 04:44 PM
deathtripper75's Avatar
I have a lone star racing block off on the banshee, and a pep easy-pull lever and perch. Although i am 95% positive that the block off will work on the raptor, i will test that theory tommorow and post my results. Nacs racing carries the pep lever, not sure what kind of block off they sell but they are all good..oh and the switch u are talking about, should be able to simply unplug it like i did with the 'shee..
-88 250r (gone but not forgotten)
-98 mx banshee
-01 raptor (blue)
Old Jan 28, 2001 | 01:26 AM
yambike's Avatar
There are two switches. If you follow the wires down into the plastic you will see that one goes to a green connector. This one can simply be disconnected. The other one goes to two clear plastic covered connectors. Disconnect the switch and then connect the two remaining wires together. Tape them up and make sure the machine starts. It should start in gear as well.
bmark0610
Sep 9, 2015 10:56 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
black_thunder
Sep 7, 2015 01:24 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
