keihin 34mm carb on 250r
Old Jul 29, 2008 | 02:10 AM
jason_250r's Avatar
Default keihin 34mm carb on 250r
I just picked up an 86 trx250r from a guy in pennsylvania . the bike ran strong there but after getting the bike home (on the gulf coast) not running as strong and will not idle . try to adjust air flow on carb (keihin 34mm pj) but no difference.
also how often do I need to replace rings ? and where can I get factory plastic and a good selection of replacement parts?
Old Sep 6, 2008 | 03:47 PM
lowlife's Avatar
Do to the elevation change, it's a good chance that you will have to rejet the carb. If the bike has a stock motor then don't replace the rings until it blows up or starts smoking alot. That way you can upgrade to a 330kit;^) For those of you reading I was just kidding. The rings really depend on the riding you do. Some shops recommend doing a top end every other year based on hours of riding. I've gone 8yrs before I blew up my stock motor without changing rings. My piston blew up due to to hot a plug and not enough premix. My fault though I was out of gas and fouled my plug but wanted to ride longer so I borrowed my buddies parts and fuel. As far as factory plastics, you may want to price them out before buying. They are much more expensive than that of say Fullbore.
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Dustinyoungs
Jul 24, 2015 07:18 AM
CRamshaw777
Jul 18, 2015 05:46 PM
