03 Honda Rincon
Old Aug 1, 2008 | 07:25 AM
Cummins123's Avatar
Default 03 Honda Rincon
Is it normal for the engine to make a tapping noise the higher the rpm. Valves were adjusted
Old Aug 1, 2008 | 10:19 AM
JeffinTD's Avatar
Hondas generally seem to make a bit of mechanical noise, so I suppose it depends on how loud...
It might be worth while to double check the valves, and if that isn't it, the cam chain tensioner might be worth looking at.
How many hours/miles on the machine.
Old Aug 1, 2008 | 12:37 PM
kukerdan's Avatar
is it fuel injected?
are you hearing the injector?
Old Aug 1, 2008 | 01:12 PM
JeffinTD's Avatar
An 03 Rincon would be carb...
Old Aug 1, 2008 | 07:00 PM
Cummins123's Avatar
It is not fuel injected. Please explain more about carb. The machine has 650 miles.
Old Aug 2, 2008 | 01:45 AM
JeffinTD's Avatar
Carb is just short for Carburetor... It should't be part of your problem.
Old Aug 2, 2008 | 08:47 AM
Cummins123's Avatar
The noise is more of a ticking sound. Could it be piston slap?
Old Aug 2, 2008 | 10:44 AM
JeffinTD's Avatar
At the miles you are at, I would think it would be unusual for it to be making much piston noise, assuming it hasn't been sunk and run with water and grit in the oil or something...
How loud is it, and did it just start making the noise? It only does it at higher RPM?
In any case, I'd still double check the valves since someone could have adjusted them between exhaust and intake or something.
Old Aug 2, 2008 | 10:54 AM
Cummins123's Avatar
I've rode it like a baby. Never been it water, and the noise is more a high rpm.
Old Aug 2, 2008 | 11:52 AM
JeffinTD's Avatar
How loud, and has it gotten louder recently?
I'd still be wondering about cam chain tensioner.
