Sport Quads Discussions on sport quads.
banshee
Old Aug 1, 2008 | 10:11 PM
bprfwarrior's Avatar
Default banshee
would u b able to run premix with e10 or would the alchohol take away the oils lubricity?
Old Aug 2, 2008 | 02:11 PM
Doctorturbo's Avatar
GOT BOOST!
Default banshee
You will be fine running E10 with pre-mix. You will also pick up a touch of power by using E10.
Old Aug 3, 2008 | 11:16 AM
Default banshee
also are the banshees like mine reliable? i want to know cuz the guy i am thinking of buying it from dropped it here for a week so i could see if i liked it.i just dont wanna hav tons of problems down the road
Old Aug 3, 2008 | 01:31 PM
GOT BOOST!
Default banshee
I don't have a shee but I have read alot about them. I know of know real problems with them. They are a good machine with tons of mods for them. A little dated though.
I would take your friend up and go have fun and see how you like it.
Some people will say you have more problems with two strokes. I dissagree. There is like 1/3 less parts in a two stroke. I own a lot of two strokes and I don't remember when the last time I fouled a plug. It's been years and years and years. They are easy to work on and fun to ride.
Old Aug 3, 2008 | 02:47 PM
Default banshee
do they foul plugs often?are 2stroke plugs the same as 4 stroke plugs?
Old Aug 3, 2008 | 03:43 PM
GOT BOOST!
Default banshee
<div class="FTQUOTE"><begin quote>do they foul plugs often?are 2stroke plugs the same as 4 stroke plugs? </end quote></div>
Depends on how good of a tunner you are. If the compression is good and you mix correctly and you have the correct heat range plug in it, you will be fine.
There are dozens of different plugs for two and four strokes. Some are the same and some are not.
Old Aug 3, 2008 | 09:10 PM
Default banshee
another question. i go to the trails every once in a while but not in the week the shee will be here.(just my luck) how would the banshees be on a long trail ride?
Old Aug 3, 2008 | 10:31 PM
GOT BOOST!
Default banshee
The banshee would not be in "my" top 5 trail quads. But, that is just me.
If you like to shift, they are fine in the trails.
Go ride one and see how you like it.
Old Aug 3, 2008 | 11:06 PM
Default banshee
k the guy is coming in about 2 days. sorry but i hav one last question.do banshees have the torque to pull themselves in first gear without throttle. sorry for all the questions
Old Aug 3, 2008 | 11:23 PM
bigned1904's Avatar
Default banshee
shees loved to be reved. there is not much power in bottom rpms. imo it is a horrable trail quad.
