05 660 special edition
Old Aug 3, 2008 | 01:02 AM
warrior1989's Avatar
Default 05 660 special edition
wat can i do to give it more power?
Old Aug 3, 2008 | 02:34 PM
Raptor450's Avatar
Same thing you do to all engines.......Pipe, filter, jet kit, cam, high compression piston...........I prefer Curtis Sparks pipes for the 660 if noise is not an issue. I also like the JE pistons, but have heard that JE had some issues with the 686 piston for the 660, so if you want a 686, CP is a good choice. I also like Webcam cam, but Hotcams makes a good cam for the 660.
Old Aug 3, 2008 | 02:42 PM
anything to do that is cheap to start out?
Krait's Avatar
Generally for the 660 an aftermarket airfilter, slipon exhaust, and jet kit will make a good boost in power. Next would be a cam, Hotcams has a mudbuster for lowend, Webcams also makes some decent cams. Depending on how you ride, trails, tires, etc, then a clutch kit could make a good difference as well in transfering power to the ground.
If you don't have the money for an aftermarket exhaust, you could do the filter, jet kit, and gut your stock exhaust...if done properly can net some decent gains...so I have read anyways...
Wiseco also makes pistons for the 660's.
MikeyBoyesq
Sep 22, 2015 10:02 AM
black_thunder
Aug 19, 2015 03:23 AM
greek271
Aug 8, 2015 08:16 PM
ltrmc02
Jul 22, 2015 04:50 AM
maxjung
Jul 14, 2015 02:22 AM
