scrambler front struts
Old Aug 5, 2008 | 02:18 PM
kukerdan's Avatar
Default scrambler front struts
Hey yall
I have the 96 400 4x4 with original front shocks,
my rear is off a 97 500, and is in pretty good shape
but the fronts are stiff and bouncy
What Can I do?
I will replace just the struts, struts and springs, or whole
damn assembly off a newer scrammy
I know about works, and will go with them if need be,
What i want to know is, what year scrammy had
the best front struts/ springs? and will they bolt up!
thanks
Old Aug 6, 2008 | 12:49 AM
Strut cartridges should supercede to Updated version,much better! Springs should be ok, I have just replaced cartridges and used original springs IF not sagging. Also can raise cartridge up a little in strut instead of bottoming out when replacing,will give slightly stiffer ride without having to go the HILIFTER route which I personally dont like because of stress on suspension! READ back of HILIFTER kit and their DISCLAIMER about suspension wear! I just installed a kit on a new Ranger Crew and I know it will be back soon! The extreme angle of rear driveshafts is ridiculous! Just to look sharp. I know ,I know many will disagree,But I am the one that has to repair these things on a daily basis. I JUST LIKE STOCK for dependability reasons.
Old Aug 6, 2008 | 05:43 AM
user493's Avatar
Moto Psycho
I think the new springs and struts have 1.5" more travel on them.
I like almost everything stock because it works and I don't want to screw it up.
Old Aug 6, 2008 | 07:29 AM
scramblerXrated's Avatar
if your wanting to replace the shocks with the newer style, youll need to replace the whole strut housing too. the newer shocks are a larger diameter and will not fit in the older housings. the older diameter is 1.5 inches, newer is 1 5/8
x
Old Aug 6, 2008 | 09:05 AM
kukerdan's Avatar
If I were to say, buy these
http://cgi.ebay.com/ebaymotors...16QQitemZ230277393251
Would I be set?
Will everything else I have bolt up?
(hubs ect)
Old Aug 6, 2008 | 12:00 PM
should bolt right up. looks like a great price too.
X
scram5050
Aug 30, 2024 01:39 PM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
