clutch belt light on kfx700!!!!
Old Aug 7, 2008 | 04:21 AM
stuntman700's Avatar
Default clutch belt light on kfx700!!!!
my CHECK BELT light when on a day ago so i opened ma clutch cover where the clutch belt at and it does apear to be wasted what should i do???any suggestions guys help me out thanks!!!!!!!!!!!!!!!!!
Old Aug 7, 2008 | 09:37 AM
stonny9's Avatar
check out kawieriders for kawasaki atv info.
At about 100 hrs the belt light is know to come on telling u to check the belt. You reset it by unplugging some sensors with a certain procedure. search the site I mentioned and u should be able to find it.
I may have the procedure in one of my post search user stonny9 keyword belt
Old Aug 7, 2008 | 10:50 PM
VTprairie's Avatar
you could just put a dyna in and never have to reset it again and get some sweet gains in the power dept.
Old Aug 11, 2008 | 05:13 AM
but isnt their a way were i can just reset the light because i checked the belt and it wasnt even used up cracked or anything...i heard it turs on every 100 hours of riding!!some one pleasee help!!!!!
Old Aug 11, 2008 | 05:14 AM
hey u wouldnt happen to know how to reset the light would yOU?
Old Aug 11, 2008 | 08:16 AM
VTprairie's Avatar
go to nyrocatv.com and go to the tech tips its in there
The KFX700 belt check indicator light turns on after 100 hours to cause you to take it to the dealer and get the belt checked. This procedure is for people that are skilled in checking the 700 belt. Do not reset the light without confirming that the belt is in good condition and is adjusted proberly. A worn or cracked belt can be usafe for the rider.
Turn ignition off.
Inspect or replace belt as neccessary (P/N 99924-1315-01). You have to take the cover off and measure the deflection.
Remove Seat.
Locate the two 4 pin connectors under seat. One is black and the other is grey.
Disconnect both connectors and reconnect them to their opposite color (black to grey, grey to black).
Turn on the ignition switch.
The belt indicator light should flash.
Turn off ignition switch (note that the hour meter is reset when the key is turned on).
Disconnect the two connectors and reconnect them to their same color (black to black, grey to grey).
Turn ignition back on and confirm that the belt light is not on.
I just copied and pasted it from there site good luck
Old Aug 12, 2008 | 04:52 AM
hey man thanxx for the infO!!!!!!!!!i appretiate it alot i will try it tommorrow morning and let u know how it goes!!!!!!!!!THANKS!!!!
ghost civic
Jan 15, 2020 07:43 AM
toonces
Jul 31, 2015 09:27 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
