How to make EFI brute run off methanol???
Old Aug 10, 2008 | 05:38 PM
edbaxter5's Avatar
Default How to make EFI brute run off methanol???
Can anyone tell me if they have one runnin off methanol and how to do it and whats the pros and cons?
Old Aug 10, 2008 | 09:29 PM
bigpig750's Avatar
Well I don't recommend it. According to a fuel site; http://www.smokemup.com/tech/fuels.php you will have to totally redo your fuel system. Lines will have to be replaced, you'll need a higher volume fuel pump, and know someone that can reprogram your EFI computer to bump up the flow of fuel through the injectors that you'll have to replace to handle the flow. Luckily your ignitions will work just the way it is, but with the other work involved with this project with the looming fact that your factory waranty will also be void with this change.
I say again I don't recommend this change. It will net a possible, but not guaranteed,
20% net increase in power. You could use nitrous and have twice the gain at half the cost.
Hope this helps.
velcro7279
Aug 24, 2015 01:15 PM
Rollin23
Aug 13, 2015 01:12 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
toonces
Jul 31, 2015 09:27 AM
Nazz26
Jul 30, 2015 11:51 AM
