still working on 2000 bear
Old Aug 12, 2008 | 07:31 PM
nina's Avatar
Default still working on 2000 bear
We had lots of advice to check stator, so we pulled it apart and the stator does not look burned, but had oil all inside. We didn't think this was right????????? does anyone know?
Old Aug 13, 2008 | 05:48 PM
HeftyLefty's Avatar
The shaft seal is gone. Its allowing engine oil to splash on the stator. Replace it and clean the stator good with 2+2 Gum Cutter to get the oil residue off. Reassemble and retest.
If you need a new stator, try www.rickystator.com
Old Aug 14, 2008 | 06:07 PM
taggart's Avatar
it is very hard to see with your eyes if stator is bad i agree with looking for burning but the best way is to get it tested by a pro . you will probably find continuity in all wires but this doesnt mean its ok , i see alot of yamahas with this problem and my money would be on the stator . get it tested by a rewinds company . they can be rewound if its bad , you dont have to buy a new one .hope this helps
Old Aug 15, 2008 | 02:00 PM
nina's Avatar
Yes we going to go ahead and replace the stator. We get no continuity or no reading at all. Although the yamaha dealers repair shop said that it should have oil in the stator. Also going to change out the regulator to. Hope this work, if not back to square one. Thanks alot.
Mkp
Mar 28, 2020 03:50 AM
rcappie4
Jun 21, 2015 07:33 PM
wbfjim
Jun 8, 2015 06:20 PM
volsgo30
Jun 4, 2015 06:07 PM
Smokinthebear
May 7, 2000 08:01 PM
