Throttle response issue KFX 400
Old Aug 14, 2008 | 03:35 PM
SKW34's Avatar
Default Throttle response issue KFX 400
Hi, first time posting. I have a 2004 Kawasaki KFX 400. When I give it gas I get the normal burst of power, then a second or two later there is a huge loss in power. This happens when the gas is in the "on" position, but not when I switch to reserve. Any ideas?
Old Aug 28, 2008 | 05:38 PM
Honda777's Avatar
That is strange , my first thought was air filter but why would it do that only in the on position , Iv'e heard storys of the stem on the petcock breaking off in the gas tank breaking off , you could pull your petcock out of your tank and check it out.
Old Aug 28, 2008 | 05:55 PM
Williebee's Avatar
There should be a screen on the petcock/onoff valve , the screen is on the on tube and probablly has trash obstructing the fuel flow ; the reserve tube doesn't have a screen only the on part of the valve has the screen !
If this is the problem after cleaning i would replace the rubber 'O' Ring and install a clear fuel filter in between the fuel hose ( between the petcock and carb ) , this will help prevent trash from entering the carb ; and you can see at a glance if trash or water gets in your fuel again !.....
Old Sep 18, 2008 | 10:40 PM
dropin1984's Avatar
when the problem occurs, does it only happen once or is it concitent until you put it in reverse
skinnyr6
Aug 25, 2023 02:18 AM
GregM
Mar 6, 2018 06:53 AM
skeets44
Jul 17, 2015 01:04 PM
Unzzy66
Jul 11, 2015 10:01 PM
MNatv89
Jul 7, 2015 11:36 AM
