Dinli 50 runs wierd
Old Aug 15, 2008 | 10:49 AM
rombi's Avatar
Default Dinli 50 runs wierd
Great site here just found it. Here is my problem. My daughter's Dinli 50 starts fine and runs like nutts wide open but when you come to a stop the motor stalls and is hard to start. If you plug the intake with your thumb the motor picks right up and off you go. So I am assuming that there is a carb problem and if I can fix this myself I will. The plug is clean. I adjusted the mixture setting and that did nothing. I took the air filter off and it still ran like that. Fires up and takes off, I can rip around the yard all day long with it but as soon as I stop it "chokes out". As it is choking out if you thumb the air intake it will come back to life.
Old Aug 15, 2008 | 02:20 PM
89stp's Avatar
Sounds like a carb problem or a vacuum leak between the carb and head.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
