Mojave won't Idle
Old Aug 18, 2008 | 01:24 PM
crackerhigher's Avatar
Default Mojave won't Idle
I am having a problem with my mojave idling. My stator died on it 2 yrs ago and I never messed with it until now. I got another stator and got it firing again and when I cleaned the carb of coarse it was all gummed up from sitting, so I clean the carb out really well and also cleaned the jets. The one jet that is kinda recessed down in the hole which I think is the pilot jet has a very faint light coming thru it and I am thinking this is still clogged. I tried needle and it won't go all the way thru it. I also soaked it in carb cleaner and it is still the same. I was wonder if soaking it in bleach will clean the trash out or is this a bad idea. Hopefully this is the problem why it won't run right. Also the choke has to be on for it to run and when the throttle is pressed to half or WOT it will die.
Old Aug 22, 2008 | 04:00 PM
kukerdan's Avatar
buy a new jet, heck, buy all new jets, go up a size from stock, at the dealer new jets will only cost you a handfull of $$..
Or buy a rebuild kit, 50 $ or so
or a newer carb off ebay, again 50
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
