Can you regear a 2004 Rincon
Old Aug 20, 2008 | 10:30 AM
Bigcop's Avatar
Default Can you regear a 2004 Rincon
I have a 2004 650 rincon, We use it for my wife to ride. It will run 28 mph in 1st gear is there a way to regear it so it will hold back better. Something like changing the gear ratio in the diff.
Old Aug 20, 2008 | 10:51 AM
TLC's Avatar
TLC
Yes there is a gear reduction,hard core mud running people do it on there ATVs all the time.
Read this thread http://www.highlifter.com/foru...duction/tm.htm#2607866
Old Aug 20, 2008 | 12:29 PM
kukerdan's Avatar
28 in 1st? sheeeeit
Old Aug 20, 2008 | 11:43 PM
JeffinTD's Avatar
The gear reduction kits on the market are like a 28% reduction or so.
They are intended to improve performance with 29" and up tires, but I don't think they have enough of a reduction to improve compression hold back on downhill sections. Also they are fairly expensive and about 5 hours or more of work to install.
The Rincon has excellent handling, reliability, and probably the best suspension of any IRS 4x4 I've ever ridden- but I'd count the lack of a low gear or low range as one of the biggest bonehead things Honda has ever done.
Bottom line: I doubt you would be happy with a gear reduction kit if you are looking for better hold back, so I guess the choices are either get used to using the brakes when you need to steep downhill below about 12, or if you can't tolerate that I think you would be better off trading it off.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
