Help carbs popping off
Try glueing the carb. to the manifold.LOL.
I'm still trying to recover from the one that smoke me upside my head.
A man can't even ride his polaris on the trails anymore with all these new "anti polaris defence mechanisms" yamaha has created.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
SCRAMDADDY400
I ride a bomb and two of my buddies ride the raptors. I haven't seen this problem on either one of theres. Really, there hasn't been any problems with theres but a little water in the choke cable that froze up(power wash). But I have read the same thing that Whittd said in other post. Get the spec.'s and adjust the clearance or contact your dealer. Good Luck.
If your quad has 20 or more hours on it get the valves adjusted. The airbox has slotted mounting holes and if u loosen the two rearmost bolts,u can slide the airbox tword the carbs. Your problem may also be a lean condition(possibly from your choke cable becoming disconnected or freezing shut), if its real cold out my raptor runs lean. Hope ive helped
-88 250r (gone but not forgotten)
-98 mx banshee
-01 raptor (blue)
-98 mx banshee
-01 raptor (blue)
Play around with your air screw they runnin to lean backfiring and blowin the carbs outa the boots happeneed to me 3 times b4 they knew how too fix it.
stay tuned to www.atving.com they said "Further analysis determined the carbs had been blown off the intakes! It seems the retaining clamps don’t clamp the intakes tightly enough and if the motor sneezes….. look for a fix from our Sport Editor in the near future." is what they said on there staff ride in pa.
