Banshee
Old Aug 26, 2008 | 09:24 PM
tricksh@t's Avatar
Default Banshee
it started only in first gear with good traction when you torqued it. it would slip for a split second and then grab creating a loud crack. slowly but surely now its doing it in every gear. any ideas or comments would be much appreciated.
Old Aug 26, 2008 | 09:28 PM
Sidewinder500's Avatar
Default Banshee
id start with checking your sprokets sounds like they may be worn or cracked and you are slipping the chain. just a thought
Old Aug 26, 2008 | 09:34 PM
tricksh@t's Avatar
Default Banshee
I know its not the sprockets their only about five months old and in good shape. The crack sound comes from the motor mainly on the left side i think. I dont think its the transmission because its in every gear. I dont know but could a clutch do anything like that.
Old Aug 26, 2008 | 09:35 PM
Default Banshee
im guessing its not backfiring cuz you didnt say that.
Old Aug 26, 2008 | 09:37 PM
tricksh@t's Avatar
Default Banshee
no the motor just screams. runs great but its something in the running gear. nothing stupid like bearings in the swing arm and the axle slapping. checked all the simple things.
Old Aug 26, 2008 | 09:38 PM
Default Banshee
check your left spark plug... see if it is fouled out
Old Aug 26, 2008 | 09:41 PM
tricksh@t's Avatar
Default Banshee
not the plugs the motor runs incredible.
Old Aug 26, 2008 | 09:47 PM
Default Banshee
may have to pull the engine apart and check your clutch, clutch basket and springs
Old Aug 26, 2008 | 09:51 PM
Default Banshee
not sure if that sound your hearing would be caused by a clutch issue since ive never had that problem on my shee maybe someone else will chime in soon and give you some direction
Old Aug 26, 2008 | 09:59 PM
tricksh@t's Avatar
Default Banshee
thanks for helping. i should probably just pull the thing apart and find the problem.
