Dang - I put tacky lube on my o-ring chain
Old Aug 27, 2008 | 08:47 AM
budedm's Avatar
Default Dang - I put tacky lube on my o-ring chain
It was a mistake. My wife's has a regular chain and mine has the o ring chain. I just wasn't thinking and I lubed both with the same stuff - the tacky stuff. Boy did it ever bind up my chain. I'll clean it with kerosene tonight and start over. Would chainsaw bar & chain oil work for a lube?
Old Aug 27, 2008 | 11:05 AM
JeffinTD's Avatar
Personally, I'd buy some O-ring chain lube. I used to use PJ-1 on the last O ring chain motorcycle I had.
It seems like the purpose made chain lube sprays on thin so it can penetrate, then when the solvents in it dry off what is left is stickier, thicker and waxier so it won't sling all over the place.
Old Aug 27, 2008 | 11:08 AM
kukerdan's Avatar
yeah it would..
you dont have to get crazy
wd-40 is nice
dry graphite is nice if you dont hit the water to much
all those chain lubes in a can work well
you dont want anything thick and sticky, it picks up and holds dirt
Old Aug 28, 2008 | 09:27 AM
budedm's Avatar
Well, I took the chain off and soaked it in kerosene. Man, it's got some links in it that are almost non-moveable. I mean they are TIGHT. I worked with it for about 30 minutes and finally gave up and let it soak overnight. Is there any way to free a chain up? I find it hard to believe that the tacky lube caused this. I think it was like that when I bought it and I didn't notice.
Old Aug 28, 2008 | 12:13 PM
kukerdan's Avatar
yeah
get some p blaster
and jack the rear of the bike up, throw it in 2nd or 3rd and let it spin and break in for
a while
if that doesnt work, its a POS return it and get something different
blueandy88
Sep 7, 2020 03:11 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
