2008 Rubicon CTE front locker
Old Aug 28, 2008 | 05:12 PM
mudlicker's Avatar
Default 2008 Rubicon CTE front locker
Is it possible to put a front locker on a 2008 Rubicon CTE?
Is so where can i buy one?
thanks
Derrick
Old Aug 28, 2008 | 05:32 PM
DSCRAZY's Avatar
look on highlifter.com
Old Aug 28, 2008 | 06:58 PM
Williebee's Avatar
Warn makes a locker that works on some Rancher models with fulltime 4x4 , that allows you to switch between 4x4/2x4 ; i don't know if they make one for the Rubicon CTE !....
Old Aug 28, 2008 | 08:57 PM
action450s's Avatar
^^^Thats not an unlocker, that is a 2wd to 4wd shifter, and I imagine the 2008 Rubi has that already.
He is looking for a locker that locks the front differential so both front wheels drive with no slippage. Detroit Locker makes ATV lockers and Highlifter sells them.
Old Aug 28, 2008 | 09:28 PM
Williebee's Avatar
Well in that case just grabb the front brake lever and both front wheels will locktite giving you a locker at no extra cost !....
Old Aug 29, 2008 | 12:07 AM
DSCRAZY's Avatar
Aww, the front brake trick again. Kinda popular around here. If you put a locker in the front, won't it make the darn thing almost impossible to steer?
Old Aug 29, 2008 | 09:41 AM
action450s's Avatar
If you install the highlifter spool like I did ($35 USD) it makes steering much stiffer on a hard surface going very slow (especially stopped). Once your moving more then 2-3 MPH its not nearly as noticeable. I havent expereinced any mechanical failures due to the extra strain, or weird tire wear either, I've been running it 3-4 years now.
With the more expensive detroit locker, that unit unlocks when you let off the gas, and lock when your into it. If you have the bike in 2wd then the unit stays unlokced for easy steering.
Old Aug 29, 2008 | 09:54 AM
mudlicker's Avatar
Detroit locker will be the one ill get if i can find it for my bike....
Dont see it listed though...
Will call them and see sometime over weekend..
Thanks for the input guys...
velcro7279
Aug 24, 2015 01:15 PM
RedRancher
Jul 10, 2015 06:36 PM
traumajunkie
Jul 5, 2015 03:03 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
