660 on rear wheels?
Old Aug 28, 2008 | 09:19 PM
finny6944's Avatar
Default 660 on rear wheels?
ok, I was experementing on whether or not I could haul my raptor along side a dirt bike. So I flipped the raptor on the rear wheels and gas started to pour onto the garage floor..I did turn the gas off, however I forgot about the gas in the carb.
So, now when I stary it, it runs rough and when I give it gas it stalls. Next I made my second mistake , I turned that little screw that adjusts the idol which I have no business doing because I dont know what Im doing.
End result, my quad wont start and Im supposed to be going away sunday for a riding weekend? Please help..
Thanks dan
Old Aug 28, 2008 | 09:39 PM
bprfwarrior's Avatar
k,try turning the idle screw to the right then try.if that dont work take apart your carbs and see if the floats are stuck. hope this helps
Old Aug 28, 2008 | 09:41 PM
finny6944's Avatar
fok will try the first step..but as far as checking the floats I dont know how..Is it pretty simple if I get the seat off and the air filter>..Thank you very much
Old Aug 28, 2008 | 09:46 PM
no problem, i dont think you need to remove the whole carb setup you can just take the bottom of the carbs off im pretty sure.
Old Aug 28, 2008 | 09:57 PM
finny6944's Avatar
ok I tried turning the screw and it didnt fire up..I opened the choke and it did fire up...i gave it a little throttle and it died and would not restart..i dont know how to get the bottom of the carb off..sorry im illiterate to engines.
Old Aug 28, 2008 | 09:58 PM
how much did you turn the screw?
Old Aug 28, 2008 | 10:01 PM
finny6944's Avatar
Half a turn? is there a way to get the screw back in the middle >
Old Aug 28, 2008 | 10:02 PM
tricksh@t's Avatar
just a thought but did you turn your gas back on
Old Aug 28, 2008 | 10:03 PM
finny6944's Avatar
yes I did..
yea u gotta turn it more than that u knida just gotta play with it till it fires then let it idle then turn the screw more.
