Alumium pieces in oil lines
Old Aug 29, 2008 | 11:50 PM
Thor487's Avatar
Default Alumium pieces in oil lines
Could anyone tell me why I'm getting alumium pieces in the oil, I broke 3 oil
pumps already, The chain is new and tight. I flushed the crankcase and the
cooler out. Its ok on low rpm's but it sounds a little different on high rpm's.
Please tell me what else to check. Thanx
Old Aug 30, 2008 | 12:16 AM
ATC250R4ever's Avatar
What kind of quad do you have? Check out your clutch, sounds like the basket is coming apart to me. If it is, replace it with a Hinson basket, they are lighter and 500% stronger than stock. Unless you have a gear rubbing the case or major top end damage, there really aren't any other moving aluminum parts.
Old Aug 30, 2008 | 10:48 AM
Thor487's Avatar
I have a Kawasaki a prairie 360 4 x4 I also replaced the front chain guide, it
waas in bad shape, I don't no where these alumium pieces are comming from?
I didn't no the clutch had any thing to do it. I was wondering if I could drain the
oil and run the engine for about a couple of seconds with the cam gear cover off.
To see if the chain is running true. Please help!!!!!!!!!!!!!!
Alex G.
Sep 11, 2017 11:38 PM
Mar 21, 2016 06:30 PM
Oct 10, 2015 10:20 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
toonces
Sep 5, 2015 01:14 PM
