325 Trail Boss from Hell
Old Aug 30, 2008 | 03:40 PM
arnard's Avatar
Default 325 Trail Boss from Hell
My aunt and uncle have a 2002 Trail Boss that they use to ride around on their farm. They ended up putting rusty gas in it for about 6 months. I got the job of completely cleaning the fuel system and cleaning the carb.
While I was doing this, the boot end of the coil broke off, the handlebar on off switch went bad and the battery shorted (causing the switch I believe). I also replaced the stator in my search for spark. Anyone need a good used one?
So anyway the machine is back together now and lucky me it has the exact opposite problem it had before. Now at idle the thing screams like a Banshee at WOT. The idle adjustment has no effect on it, but the throttle does respond when pressed. Is it possible that when cleaning the carb I made the jets too big when I rand cleaning tips through them? I usually use oxy torch cleaning wires and have never had an issue like this before. I have turned the adjuster on the bottom of the carb all the way in with no effect. That was fun by the way. I also even took the choke cable all the way off to see if that was the issue.
Is there something I am missing here?
Does anyone make a carb kit for this machine (which I believe would be the same engine as the 325 Magnums) or do I have to buy everything piece by piece from Polaris if I go that route?
Old Aug 30, 2008 | 03:46 PM
allenduren's Avatar
hi you need to go out with your idle adjustment... ebay has carb kits but who knows how good they are.. go to denniskirk.com they got lots of stuff and they are reasonable and fast shipping!! get stuff next day from them and on 6 dollar shipping
Old Aug 30, 2008 | 03:49 PM
allenduren's Avatar
also id never use oxy torch cleaning wires them brass jets are soft.... spray lil carb cleaner through them and take blow nozzle and blows air through um.. thats my way anyways lol
arnard's Avatar
By idle adjustment do you mean the large screw that is easy to get to or the little pain in the *** one on the underside of the carb in the middle?
Old Aug 30, 2008 | 03:59 PM
allenduren's Avatar
there should be a bigger on that loops down lil bit and mounted on bottom of the carb or if hanger is broke layin theere lol... that little paint in the *** one sounds like idle air fuel mixture.... not sure where that needs set lol... but turn that bigger one out some should idle down
mine has philips screwdriver thing in middle andd has bumps all way round outside
Old Aug 30, 2008 | 04:01 PM
allenduren's Avatar
o ya dont ride it with that little screw all way in 2 stroke motor will blow sky high.... not really but probably blow up
Old Aug 30, 2008 | 04:12 PM
arnard's Avatar
This is a 4 stroke. The idle adjustment screw is already all the way out. I can physically see the throttle when the engine is running. The throttle and the gate are both closed. It has to be the mix.
Old Aug 31, 2008 | 09:46 AM
drlang's Avatar
There is a diaphram that makes the whole thing work I believe. It's on the top of the carb and vacuum makes it work. I'm not to up on 4 strokes, take a look there. Doc
Old Aug 31, 2008 | 09:59 AM
MECHANIKE's Avatar
make sure you have 1/8" only play in your thumb throttle if you have none it will rev, if you have too much run like crap.i check mine whenever i do anything in the bike................
Old Aug 31, 2008 | 01:20 PM
arnard's Avatar
I will check the throttle cable. Here is what I am thinking if that doesn't work.
Is it possible that the abrasive crap in the gas made its way into the carb (it was dirty but not too bad) and as it was forced through the jet holes it enlarged them. Then when I cleaned it I was left with a jet that lets too much fuel through?
Does that sound possible or am I stretching?
oliveiracarlos
19
Nov 11, 2015 05:49 AM
craacker
Sep 9, 2015 04:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
JakeXBL
Sep 5, 2015 01:08 PM
Canamaniac!
Sep 4, 2015 06:44 PM
