Oil and Transmission fluid changes
Old Sep 1, 2008 | 10:25 PM
hypergt's Avatar
Default Oil and Transmission fluid changes
Just wanted to see what everyone suggest on times to change fluids. My trail boss don't have an odometer or hour guage so when should I do the changes. Also is there a break in service that I need to take the atv back to the dealer for if so what do theyt do at this servicing.
Thanks
Old Sep 1, 2008 | 10:29 PM
cadillacdude1975's Avatar
my 99 yahama big bear service manual says to change the crankcase oil every 6 months. no mileage or hour limit stated.
if it is dirty, i would just go ahead and change it. be sure to use the proper rated oil for your machine.
Old Sep 2, 2008 | 03:43 AM
user493's Avatar
Moto Psycho
You should change the oil and filter and check all the fluids at least twice a year. Spring and fall is my schedule.
Old Sep 2, 2008 | 10:17 AM
scootergptx's Avatar
Supersock
Hired Gun!
Break in is typically about 10 hours. You can take it back to a dealer, but they're just gonna change the oil, probably tell you the air filter is dirty (shouldn't be) change your plug (still good), adjust the valves and grease it.
They should also give it a good once over for any leaks.
All of which can be done in your own garage for a lot less money.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Alex G.
Sep 11, 2017 11:38 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
