Grizzly 660 stuck in park
Old Sep 4, 2008 | 03:53 AM
ATC250R4ever's Avatar
Default Grizzly 660 stuck in park
Ok, we're stumped. 2002 660 Griz just won't come out of park. Worked fine after fresh rebuild, ran great, rode great. We put it in park to pull a Wolvy and it has been in park ever since. Any suggestions before we go tearing the case apart? Yes we've tried rocking it, and no it isn't the linkage. I hope someone here has more experience with one of these than me.
Old Sep 4, 2008 | 11:22 PM
Traildad's Avatar
Well with my Kodiak you have to press the foot brake to allow the transmission to shift out of park. Is it possible that there is an adjustment for the foot brake that is the problem?
Old Sep 4, 2008 | 11:58 PM
Nope, that just effects the linkage, but thanks for your response. I think the problem may have something to do with the shift cam or the stop cam, just wondered if anyone else knew anything about it. I'm gonna start tearing it apart right now.
Old Sep 5, 2008 | 03:11 AM
Traildad's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ATC250R4ever
Nope, that just effects the linkage, but thanks for your response. I think the problem may have something to do with the shift cam or the stop cam, just wondered if anyone else knew anything about it. I'm gonna start tearing it apart right now.</end quote></div>
Interesting, I thought pressing on the foot brake moved a "lock" out of the way that kept the shifter from moving. Are you saying that you disconnected the linkage and tried to shift at the transmission and it still wouldn't move? Well good luck.
Old Sep 5, 2008 | 04:41 AM
Yup, it's not the linkage. Depressing the rear brake, either at the foot or the hand releases a stop on the shifter **** itself. It's almost apart, engine is on bench, I just need to split the case and see what happened and why. Thank you for the input, much appreciated.
Old Oct 25, 2011 | 09:05 AM
ryder#1's Avatar
I have an 06 kodiak 450 stuck in park. All was well when I parked it 3 weeks ago, now it won't move. any ideas?
Old Oct 26, 2011 | 01:16 PM
Camo-man's Avatar
My buddies Kodiak did the same thing. pulled off side panel under gas tank and linkage bolt came out.....
Old Oct 26, 2011 | 01:54 PM
hammond31's Avatar
Default same thing with a brute 650
take the side cover off and check the bold like camo-man said it should free it if not start it and pull all brake levers and try it sometimes mine does that if not i will talk to a friend he work at a yamaha dealer he would know
Old Oct 26, 2011 | 05:30 PM
ryder#1's Avatar
Thanks for the reply, I took the side cover off, the linkage is still connected. Should I take the bolt out and then try to move the linkage or what is the next step?
Old Oct 26, 2011 | 05:43 PM
hammond31's Avatar
if you take the bolt out and it should let it move out of part and once you get it out put the bolt back in and just snug it like you would a oil drain plug. If that does not work your trans is locked up.
