02 Sportsman 700
Old Sep 6, 2008 | 10:37 AM
Paul.E.Wog's Avatar
Default 02 Sportsman 700
Please help. I just purchased a 02 Sportsman 700 and noticed it started to make a wierd sound when it is moving. When in low the sound only happens when you are moving quickly, in high it happens right away. It sounds like a whistle or a wine of sorts. I thought maybe belt, so I took off the cover to look and it appears to be in great shape. I lifted the back wheels off the ground to take a listen when its sitting still. The AWD was OFF, and when I gave it throttle the AWD kicked in about 5 seconds after the rear wheels were spinning and the atv just about drove itself into my sled. Whats up??????? Any ideas????? Thanks
Old Sep 6, 2008 | 09:55 PM
MECHANIKE's Avatar
IF YOU WERE SPINNING THE REARS FAST SOMETIMES ONE OF THE FRONTS HAVE BEEN KNOWN TO KICK.CHANGE THE FLUID MIGHT HELP...
Old Sep 6, 2008 | 10:15 PM
jodaanja's Avatar
I might be buying the same machine tomorrow.... an '02 700 Sportsman. Does this machine have a Hilliard clutch in the diff like my '07 700 EFI? or does it have the clutches on the wheels like my 2000 magnum 500?? I haven't been to look at it yet.
Old Sep 6, 2008 | 10:49 PM
sp700cheapskate's Avatar
Hilliard system in the diff. It is pulling the front tires because it has some problem with the cage up front and it will engage when it is not supposed to. This is caused by the awd being engaged at too high speeds. I've heard that the rollers will grind grooves and when the grooves get bad it will do this. The diff components can be bought cheaper from john deere for the gator. I also hear that these parts are much tougher. I've heard that it will run a long time like this, but if you like to do doughnuts I would recommend fixing it. I say this because if you do doughnuts in 2wd and you're screaming the motor and AWD engages its not good on the front diff.(grenade!!)
Old Sep 6, 2008 | 10:52 PM
By the way, I own an 02' 700 and I love it. I hope you do too.
Old Sep 6, 2008 | 11:42 PM
Also inncorrect or low fluid may cause this.
Old Sep 7, 2008 | 12:30 PM
MECHANIKE's Avatar
what also can happen when doing donuts is if the front kicks in you can instantly flip over, i've seen it on youtube. did not look fun.looked like it squished him like a bug...
Old Sep 7, 2008 | 04:49 PM
Paul.E.Wog's Avatar
Does your 700 make any noise when its in high gear?
Old Sep 7, 2008 | 10:43 PM
yep, it clunks and whines a little. I'm told its normal. I maintain it as best I can and pray for the best. My friend had a 700 ranger(side by side) and the xmission was much louder than mine. Everything else seemed to break but not the xmission and engine.
Old Sep 8, 2008 | 06:10 PM
Paul.E.Wog's Avatar
Well that makes me feel alot better. Thanks. If you can think of anything else I should do to it please let me know. A friend told me to put a clutch kit or a carb kit in it, what do you think?
